Widget Doesn’t Respect Hide All Subtags
Build 11416
Adding sidebar widget and having it filtered on a tag
Sidebar widget
It ignored “hide subtag notes”
I expected it to mirror the app and show the tags notes without subtag notes. This may be a limitation of widgets through. Not a big deal if it doesn’t work with the way iOS handles widgets.
Thanks for reporting this. Yes, I think the correct way of handling this is to have the hide subtag notes honored in widgets the same way widgets behave differently when Bear is locked.
Awesome, thank you! Crazy how many areas every new feature touches.
