Wikilinks in Tables not working Bear 2.0
Testing version: Version 2.0 (9652)
What were you doing: Adding a [[Wiki Link]] to a table
What feature did you use: Tables and Wiki Links
What happened: The link did not work
| Wiki                       | Bracket                             |
| [[Econometrics (Methods)]] | [bear forum](https://beta.bear.app) |
The [[Wiki Link]] in the table to work like the http link
Thanks for reporting this issue. We’ll fix it in the next updates.
A quick update.
The links do work, but only after closing the note and reopening.
Steps to reproduce:
  1. Add [[wiki link]] to table; it does not work
  2. Open other note or close note
  3. Reopen note with [[wik link]] in table and it works.
So it works, just delayed :wink:
