For what it’s worth… I started using Bear as my go-to notebook, a mix of personal wiki, an address book, a way of keeping projects organised, etc… Some people say that no app should be an all-in-one, but the trouble is that most things are somehow connected, and using lots of separate apps makes it difficult to keep track of the connections.
To cut a long story short Bear 2 is doing an amazing job. Initially I do have a lot of data input to do (which naturally is a drag) and worse, I’m doing it on the iPad. And guess what, everything is so smooth and natural using Bear 2. (Yes, I’d prefer if the picture insert would default on library rather than camera, but that’s a minor thing)
Keep going guys, you’re doing a great job!
