Add option to draw on MacOS
Please add the option to add drawings in the MacOS app of Panda. I have a drawing tablet and would like to add small sketches to my notes. This is possible when using the iOS app but it does not seem to be possible using the MacOS version. Thanks!
Hi there,
Thank you for taking the time to post.
There may be a technical reasoning for not being able to support this, but i’d have to double check with the development team.
Thanks for the suggestion, i’ll pass it onto the team.
