Back Linking to a note/Heading does not work as expected
Testing version: Version 2.0 (10688)
What were you doing: Trying to add a backlink to a note and add a heading
What feature did you use: scrolled to a note then hit the / key to try to navigate to a heading
What happened: Nothing happens. The only way I can make this work is to hit the return key and then go back and edit the link at the very end by typing a / before the closing ]]
What did you expect to happen: Hitting / should select the note and allow me to then pick a heading within
I also noticed this. There was an explanation on the forums on this feature, but I can’t find it. I thought you should be able to type first few letters of the note name, hit enter to select, and to keep typing ‘/’ for the header.
We removed the / completion for tags because of meaningful issue concerning date tags (2023/03/29) and how they are inputed/searched with the panel. We forgot this is not the case for wiki links and it’s useful for accessing to the note’s headers. We’ll restore / for wiki links in the next build.
