If a note is open as a separate window, adding new note links no longer works.
Steps to reproduce:
- Open any existing note in new window
- Type double brackets to start a link, e.g.
- As you continue typing, no note title matches are displayed
If you then close the open window and attempt the same within the main Bear pane, linking works just fine.
