Broken indentation shortcut in v2
Testing version: 2.0.15 (12062)
What were you doing: changing indentation of a bulleted list
What feature did you use: command + [ and command + ]
What happened: cycled to the prev / next note in the sidebar
What did you expect to happen: bullet indentation to increment / decrement.
It’s the same issue reported here: Cmd + [ and Cmd + ] Shortcuts Don't Work For Indentation - #5 by wkd
However I could’ve sworn that before I upgraded to v2, these shortcuts were working…
In Bear 2, you could use tab and shift+tab (at least with English (U.S.) keyboard layout). But yes, command + brackets used to work for indentation in Bear 1. Although I do not see them reverting to that behavior from the current one.
