Bug - can’t double click to select url text
2.0.1 (11717)
Double tapping text that was URL formatted
Standard iOS double tap
Normal text was selected, url text was not
When in edit mode I’d expect to be able to select the url text also
Are you sure about that? I don’t think URLs in Bear ever worked that way. Edit in edit mode, link in ‘normal’ mode. No?
Right, but any sort of text editing should be able to result in a selection of that text. As in, because I’m in edit mode, I should be able to do edit functions such as selection the text of the URL (i.e. double tap to select just the “google” or the “com” etc)
In Bear 1 clicking the link takes you to the web page. In bear 2 it doesn’t, hence my perception that I’m editing rather than interacting. Perhaps this is having bearing on expected results?
Yes. I am having weird issues with selecting text. I am trying to nail down reproducible steps to report (as they are random). Just like the OP, when I double-tap text it either selects other text or moves the cursor to another position.
