Testing version: 2.0.17 (12140)
What were you doing: Renaming a tag with subtags
What feature did you use: Tagcons
What happened: Upon renaming a tag with subtags, most of the TagCons reverted to the default #. This is repeatable.
What did you expect to happen: I expect the TagCons that I set to remain the same.
Oddly enough, if I rename the parent tag back to the previous name, the TagCons on the subtags come back.
