When I drag and drop a Bear note into the Finder or, for example, into Devonthink, the note is exported as a text file (.txt). It would be nice if I could change this setting. I think it would make sense to export as markdown (.md), since Bear is primarily a markdown editor.
I agree, but at least all the MD syntax is there. So, copy/past does the trick, albeit not conveniently.
I admit what I wrote sounds a bit misleading. I’m only concerned about the extension .txt vs. .md. The file content/syntax is markdown already.
