Copy code block doesn't work
Testing version: Version 2.0 (9772)
What were you doing: Trying to copy a code block by using Format > Code > Copy Code menubar item while the cursor is inside the code block
What happened: Nothing gets copied
What did you expect to happen: Code block contents get copied to clipboard
yes, this is definitely a :beetle:
Thanks for reporting this issue.
