Something that would be incredibly helpful would be to have templates for Zettlekasten-style notes such as Reference Notes, Literature notes, and Permanent Notes. Or even be able to create my own templates for recipes or other repeated patterns that I use often.
Currently, I have several template type notes with #.template tag which works great if I’m starting from a blank note. However, I’ve noticed that I create a lot of notes on the fly by using the double brackets to create a note that I will later write. It would be awesome to click that note and then be able to apply a template to it.
It also would be neat to have templates that don’t get overwritten. For example, in the Adobe programs, you can save something as a template. Then when you open that document, it creates a new document with whatever you have in the template, but it doesn’t save over the template itself.
