Testing version: Version 2.0 (9652)
What were you doing: CTRL-3 after having closed the tags list with CTRL-1
What feature did you use: Show Tags, Notes and Editor shortcut
What happened: When I hit CTRL-3 again, the tags list disappears.
What did you expect to happen: Tags list stays visible.
I’m having some issues understanding this bug report, is this behavior the same in Bear 1?
I think they mean that Ctrl+3 will hide the first two panes if they are visible, and they believe this to be unintended behavior. I wouldn’t think that’s a bug?
I don’t know if it’s a bug; it seems to be the same behaviour in Bear 1. To make sure, I made a screen recording of it in Bear 2.
Cheers,
Erik Vlietinck
Freelance journalist and content writer for Fortune 500 companies and SMEs.
Yes, this is the intended behavior, and it has raised some eyebrows since we introduced this in Bear 1. However, we think it’s handy to hit the same shortcut twice to get to the previous layout state.
