Testing version: 2.0 (9735)
What were you doing: Inserting current date (medium format)
What feature did you use: Format > Insert Current Date > Date
What happened: Inserted current date (long format)
What did you expect to happen: Insert current date (medium format)
Bear 2’s date format for ⇧ ⌘ 8
is long format, not medium like Bear 1. All other options are the same between both versions. For example:
Bear 2
⇧ ⌘ 7
→ 2022-10-23 at 12:07
⇧ ⌘ 8
→ October 23, 2022
⇧ ⌘ 9
→ 10/23/22
⇧ ⌘ 0
→ 12:07
Bear 1
⇧ ⌘ 7
⇧ ⌘ 8
→ 2022-10-23
⇧ ⌘ 9
→ 10/23/22
⇧ ⌘ 0
→ 12:07
System Preferences > Language & Region > Advanced
