Will the new Panda editor support definition lists? It turns out I use them quite a bit in design documents. ATM in Bear I create these a bulleted lists with embedded tabs. Making definition lists a first-class citizen would be great!
Here’s the MMD syntax description: https://github.com/fletcher/MultiMarkdown/wiki/MultiMarkdown-Syntax-Guide#definition-lists
