Drag and drop into table cells
Testing version: Panda 1.0 (1648)
What were you doing: dragging images, pdfs onto table cells
What feature did you use: n/s
What happened: nothing
What did you expect to happen: insert images or pdfs into cell
Hi,
Yes, this is a know limitation of our table implementation. It’s possible to have images and files inside tables but generated numerous layout problems across the platforms, so we decided to keep this eventually for future implementations.
Ok. Actually, I can drag images into rows easily enough, although it would be nice to have something that auto-resizes to fit new additions to the row. Also to maintain constant height across the row. Notion handles this very nicely.
I know I’m bringing to live a bug from March, but it looks like dragging text breaks a table as well. Not only images. It’s a little bit of pain and unexpected… (the gif is slow, Bear with it)
Screen Recording 2021-11-22 at 09.24.57
Hi there,
Thank you for taking the time to leave a post. Also, thank you for the pun, it was Beary funny :stuck_out_tongue:
Regarding the above, Tables don’t currently support internal drag’n drop, so this behaviour is expected.
If you’ve any further queries or questions about Bear/Panda, let me know as i’d be happy to help :slight_smile:
