Duplicate Function Crashes Panda
Testing version: Panda 1.0 macOS (1653)
What were you doing: I was attempting to make a copy of a file using the Duplicate function.
What feature did you use: Menu Bar → File → Duplicate
What happened: Panda Crashed
What did you expect to happen: I expected Panda to make a duplicate file.
Hello!
Nice find, I was able to reproduce and fix that, next update will have this fix included :slight_smile:
Best.
On Version 1.0 (2595), this bug exist yet…
… I created a new document with links, images, footnotes…
… saved as .panda
… Duplicated… PANDA crashes…
… Tried to open saved .panda doc… “The document untitled2.panda could not be opened”
Hi there,
May I just ask, where do you have Panda located?
We’ve received previous reports that when users had unzipped Panda in the downloads folder is caused crashes.
If you move it to Applications it should be working again. Let me know if the issue persists and we’ll investigate further! :slight_smile:
