Feature Request: Option for headers same size as body text
I would love for Bear headers to be the same size as my chosen font size. Bold is fine, but the big headers are distracting to me.
You can use smaller headers like H6
But then in previews, exports, etc. it will be H6 instead of the intended header. :frowning:
This seems reasonable if you’re using just a single header level, but having all headers be the same size would break the visual contrast between header hierarchy, rendering the different levels maybe a little useless.
Do you have a suggestion for how to visually distinguish each level?
Markdown already solved for this. Hashtags. :slight_smile:
Except Bear hides markdown syntax now :kissing:
