Hello Everybody.
unfortunately, we have not found a direct way to let people purchase Bear Pro within a TestFlight beta. However, We can suggest the following workaround for to take advantage of the current prices:
- On one of your iOS/iPadOS devices delete the TestFlight version of the Bear’s app (has a yellow dot next to “Bear”)
- Download and open Bear from the App Store
- Purchase Bear Pro using the in-app preferences
- After purchasing the sync status will remain “never”
- Bear 1 will not sync if you used the beta because your online notes have been migrated to version 2
- Delete Bear’s app once again
- Download the TestFlight Version and let it sync back
- You might see a duplication of the beta welcome note
Let me know if you experience issues with the above procedure.
