Images (Attachments) stay at the same (root) file level as notes during export (not in specific subfolders)
Testing version: 2.0. (10084)
What were you doing: Exporting all files (md format / witch attachments+images / as individual files)
What feature did you use: Export (with options)
What happened: Instead of placing images/attachments in respective subfolders (each note with image has its own subfolder created with identical folder name during export), these attachment folders are empty and all images/attachments are in the same flat file structure as are text (md) notes. However, links in md files point at these (empty) folders.
What did you expect to happen: Images being in respective subfolders
Hello and thanks for reporting this bug. We’ll fix this for the next update.
