Irregular Jump of Focus to the Cursor
Testing version: 0.1
What were you doing: tried expanding the collapsed section in the sample note
What feature did you use: collapsing/expanding sections
What happened: it got expanded, but before I can see it the focus moved to the cursor which was at the top of the page. This happened when I clicked on images, tried to interact with a couple of more things. Rather than keeping the interacted object on the visible screen, it scrolls to the cursor, regardless of how far it is.
What did you expect to happen: keep the interacted object in the visible area
yes, iOS has a bad habit to scroll back to the cursor even when you don’t want that :expressionless:
We’re looking into it to prevent this from happening.
Thank you for the feedback.
