Keep tag current tag selected when callback url creates note
(I’m not sure if this is a bug or a feature request)
Bear Desktop 1.8.5
What I did:
  1. Create a note like this
# base note
[new note](bear://x-callback-url/create?title=subnote&tags=aa)
##a
  1. Select the aa tag in the sidebar
  2. Open the base note
  3. Click the callback link that creates a new note with the same tag
What I expect The new note opens, leaving the same tag selected in the sidebar
What happens The sidebar selection changes to All Notes
Use case:
I use a tag to collect all my journals. I also have a “master note” with callback links to create a new journal entry template. After clicking the callback to create a new note, I like to drag that note to the master note - such that the master note also functions as an index for all journal notes.
Since the sidebar switches to All Notes after creating the new note, I have to reselect the tag to get back to my journal entries.
Clarification: I believe the existing behavior is correct; in the case where the new note does not contain the currently selected sidebar tag.
Title should be “Keep current tag selected when a callback url creates a note”. Not sure how I got that extra word in there.
Hi there,
Many thanks for taking the time to leave a post here.
May I just ask, is this still occurring for you?
Have you updated to the latest version of Bear (1.9.2)? Does it still occur after updating?
May I also ask, what system version are you using on your device? and if possible, could you provide an example screen recording of this for investigation?
Thanks for checking in, Yes, I do still see this, on bear 1.9.2, on macOS Monterey (I was on Big Sur when this was first posted)
I did notice a mistake in the original note snippet that could have been confusing, I meant to use the tag #aa, but ended up with ##a (which means nothing)
# base note
#aa
Attaching a video that hopefully helps. When I click the link, I expect aa to still be selected in the sidebar.
Ah, I see now. I believe this is the expected behaviour as you’re creating a new note, therefore it jumps to the notes section by default.
I can also see your use case for amending this though. Therefore, I’ll pass the feedback onto our designer and our development team to discuss and possibly consider :slight_smile:
Thank you!
I can understand that this is the expected behavior! In conclusion I would just point out that using the “create note button” at the top of the notes list does not cause a jump to the notes section. And this feels like it should behave similar.
Thank you for the additional thoughts to ponder! It has now been passed onto the team.
In the meantime, hoping you’ve a Beary nice day :grinning_face_with_smiling_eyes::bear:
I know this is a year old now, and I have not tested this on the beta, but I just wanted to add that the iPad version of the app exhibits the behavior I’d expect; it is only the Mac version that does not.
I can confirm the new macOS beta will not change the sidebar selection to Notes if the note list displays the newly created note.
Best Regards.
