Links to local files with blanks in the path are not shown as links
Testing version: 2.0 (9735)
What were you doing: I have created a link to local file like [My Video](file:///Volumes/video/my video.mp4)
What feature did you use: Creating a link to a local file in markdown.
What happened: The Link is not recognised as link:
What did you expect to happen: It should be shown as link like in Bear 1:
If I’m not mistaken the URL to be valid should not include spaces and if you replace the space with %20 it will work as expected. We do this conversion automatically if you use the link panel ⌘K. You can also drag and drop the file in the URL field in the panel and prepend file://
Thank you for your reply.
That is correct.
Yes, but this conversion ist not done with migrated notes with links containing spaces from Bear1.
