Merge notes function gone?
Using iOS and iPadOS v2.0 - I can’t find the ‘merge’ notes function…has this been removed? I hope not as it is extremely useful. I can’t locate anything about the merge function in the help pages on the website either.
The merge is still available! Select multiple notes (by panning with two finger or by tapping the title of the Notes list and then “Select Notes”) and hit the 3 dot menu in the bottom right.
Thank goodness I asked! I’d never have worked that out as I was so used to tapping and holding with one finger. Thanks for coming back with the solution.
