I’ve been modifying notes. I would type a search, select the note, modify the note. Then I go back to the search, erase the old search word and start typing a new… well, that’s the idea. Usually that works but tonight I have crash after crash doing so. Also other crashes when navigating, for example when I wanted to press the ‘todo’ in the left column. Is it just me?
any chance you left a comment on these crashes on TestFlight? Are those on macOS or iOS?
I’m only using the iPad, so yes, it’s iOS. And yes, every time it crashes I do leave a comment of the testflight pop-up. So I hope you guys get the info, because I’m really not good in doing screen videos and elaborate crash protocols.
