Need to import Bear 1 notes
First, I love Bear. Have been a longtime fan and love Bear 2.
However, I’m disappointed that I can’t import notes from Bear 1. I have a lot of notes I would like to import to Bear 2 and I’m currently losing a lot of work because Bear 2 cannot import .bearnotes files. :frowning: I wish Bear would have given this use case more thought.
The only thing I can think of is to find a copy of Bear 1 and export my notes as .txt files which I can import to Bear 2. Is there a link to download Bear 1?
Does the format actually differ? I.e. if you rename it just “.bear” instead, does that import? Otherwise if you want to send me a sample Bear 1 note I can see if there’s any way to script it to modify for import
Hello, you should be able to import .bearnotes files in Bear 2. Can you please tell me more about this issue?
The files simply appear greyed out, so I can’t select them. The files were exported from Bear 1.
Renaming to .bear works! :slight_smile: Thank you!!
