BUG-report: Panda Version 1.0 (3147) on MacBook Pro M3 2023 with latest release and update of MacOS.
- Panda is now displaying old .panda docs with images: with invisible text:
- Images are displayed, but text is invisible in both in dark and light modes (these are documents saved with the former Panda alfa, including the Welcome note.)
- When I Select All (in those notes in Panda) and copy/paste into Bear, everything is revealed and looks good, so this is a curious bug.
- If I copy paste Bear Welcome Note: “Get started with Bear” into Panda editor, I’ll get the same Issue: invisible text.
- But if I then delete both images, text is revealed and everything else looks good.
- Did a clean reinstall (deleted all traces of Panda system wide), and reinstalled from the link above, but that didn’t solve the issue
