Testing version: Panda Version 1.0 (922)
What were you doing: Testing the syntax!
I typed this text to test the new input:
***~this should be bold, italic, and underlined~***.
Without the period, it parses and renders correctly. With the period at the end, it does not. The problem seems to be in the parse of the **
, specifically whether it’s at a clear word boundary. Thus, this works:
**_~this should be bold, italic, and underlined~_**.
But this also does not:
_**~this should be bold, italic, and underlined~**_.
Given the three samples above, in the same order, this is how they rendered:
All of those should parse and render the same final output.
As you can see looking at the middle sample, it is actually also not parsing correctly: it is not closing the emphasis. Continuing to type on that line produces this output:
