"Pin to top" from the note itself
I would like to be able to pin a note from the note itself (instead of having to go to the notes column to manage this). I do not get why this feature is not possible from the note itself. I find it inconsistent with other note operations I can perform on a note (e.g. archive, delete).
I also note discrepancies from the note menu (…) when a search is active and when it’s not (e.g. can’t archive) showing here,
Screenshot 2024-03-28 at 20.12.31 viewing the note normally
Screenshot 2024-03-28 at 20.12.22 viewing the note from a search
I would expect note operations to be possible regardless of how I view a note (normal, search, floating etc.)
Pinning is relative to a tag, a note may have several (or none).
No, I was wrong, sorry.
I have seen pin/unpin has a global effect and the note is pinned in all listings it appears in. Guess I assumed it was relative to the tag because of the item in the contextual menu in the tag listing. Indeed, the “Note” menu has “Pin To Top” (⇧⌘P) too.
Please, disregard my reply.
