Pin/unpin subtag discrepancy
Version 2.0 (10670)
Pinned a tag. Then renamed it to make it a subtag.
The subtag remains “pinned” visually but cannot be unpinned.
I would expect the subtags to be pinnable. Not sure if this should be working, or not, by design.
It seems like Bear 2 does does not allow subtag pinning, but the behavior I’ve achieved is kind of working - the subtag is listed on top of the subtag list. I just can’t unpin/re-pin it.
Sounds like a glitch but I don’t understand what’s happening. Can you please send a quick screenshot of the visually pinned subtag?
Here.
To reproduce (can on both Mac and iOS):
  1. Rename tag/subtag to subtag
  2. Pin subtag
  3. Rename subtag to tag/subtag
