Removing nested italics adds more asterisks
Testing version: Panda 1.0 (3096) on macOS 12.5
What were you doing: Adding and removing bold/italics with Command+B and Command+I
What feature did you use: Nested styles
Start with text that is both bold and italics: ***Sample***
Removing bold with Command+B will change the text to *Sample* as expected
Removing italics with Command+I removes italics by adding additional asterisks ****Sample****
Removing italics (Command+I) from bold+italics text (***Sample***) should remove asterisks to: **Sample**, just like removing italics from text that is only italics: *Sample* to Sample.
Hello!
Thank you for submitting the bug, I can confirm this is not supposed to happen, we’ll patch it as soon as possible :slight_smile:
Best.
