Shortcut for checkbox
Hey folks,
Is the shortcut - [ ] dropped from Bear version 2?
Shortcut for todo check box: ⌘T (command + T)
To toggle check/uncheck: ⌘. (command + period)
But what is the Markdown code for the check box?
  • unchecked = dash space [ space ] space
  • checked = dash space [ x ] space
Note! Temporarily becomes bullet point while you type this markdown code, but after typing the last space, it changes into an interactive checkbox.
Markdown:
- [ ] unchecked
- [x] checked
Thank you! I wish Commonmark’s website would have simple documentation like that for all markdown features. They do for some, but not all.
Previous Bear 1 behavior to type - unchecked was convenient to create todo items across iOS & Mac.
Is restoring the previous behavior under consideration?
I don’t know that todo’s are actually in the spec:
https://spec.commonmark.org/0.30/
If they are, I couldn’t find them
Totally agree that - unchecked was the pinnacle of usability for checkboxes
Todos are not in the original CommonMark spec, they are a Github extension which most editors adopted as part of the CommonMark standard.
