Hi,
while writing notes – even quick notes – I use a lot keyboard-shortcuts for styling text (like CMD+B
for bold or CMD+I
for italics). Something that I can’t used to is the “Bear behaviour” with them: if I’m writing some words in bold and I press CMD+B
, all the stuff I just wrote revert to regular text. What I’d like to happen is it to end the bold section, moving the cursor after the double asterisks used to mark bold text. This would be particulary helpful when markdown need a double character: right now I have to hit the right arrow button twice, or press CMD
or ALT
at the same time.
I know that Bear – and Panda too – allows to quickly disable styles simply moving the cursor in a styled piece of text and pressing the right shortcut. But I feel that this is what should happen if the user clicks somewhere in the document or use arrows to navigate, not when he is typing something. Not a big deal after all, but it’s something that in my opinione would make writing a bit quicker and easier.
PS: the same should happen on mobile when using the styling toolbar.
