Shortcut search result is not listed as expected
Testing version*: iOS 2.1.6
What were you doing: execute shortcut which included an action “Search notes” with function “Open In Bear” disable.
What happened: Using a shortcut to search for specific keywords, but the search results are not fully listed. The search results from the Shortcut Action differ from those obtained by searching within the app; the results within the app are accurate.
What did you expect to happen: Find the correct results.
