Sketch/Handwriting randomly chages size
Testing version: 2.0 (10641
What were you doing: I went back into a note with a sketch field that I previously created.
What feature did you use: Handwriting/Sketching
What happened: My handwriting kept resizing. Sometimes it grows larger and sometimes smaller even without resizing the field itself.
What did you expect to happen: The size should remain the same
I had the same problem in the first release. Then with the release on yesterday, the problem seems to be solved, I do not have the problem for the last two days.
Thanks for sharing. I think you might be right. I tested this morning and the sketch field seems stable now. Will continue to play around with it.
