Tables with pipe symbol in a cell break when reloading Bear
Version 2.0 (9969):
building a table:
the table building feature:
if a table cell has a pipe charactert in it, when Bear reloads the table, the table is broken:
That the table wouldn’t break:
Create a table
| aaaa | bbbb | cccc |
| aa | bbb | ccc |
Table created. Now add a pipe - ‘|’ symbol into one of the cells, quite Bear and restart. The table is broken,
I get why this would happen but there should be some kind of warning, or have the character escaped when it’s entered.
This alos highlights a problem with pasting tables. Basically you can’t. I can think of all sorts of reasons why this might be wanted but specifically, in the case outlined above, I can’t recover the (long) table by symply pasting the markdown into the page. I have to copy and paste each cell by hand.
yes, we can do better with the | parsing inside of Tables. We’ll add this to future updates.
Thanks for reporting this.
I encountered this issue when I tried to link a note with custom name inside a table cell.
[[note]] works fine
[[note|my note] breakes the table
You don’t need to restart, just switch to other note and back.
Here is how it looks:
While editing
While inside note
Switched to other note and back
