Tags get indented when adding a list above them
Testing version: Version 2.0 (10641)
What were you doing: Just entering Markdown code
What feature did you use: None
What happened: I added a list, in the line above my tags, by entering a * and when Bear added the formatting for the list it indented the tags as well.
Even when I added two line feeds to exit from the List the tags were still indented
What did you expect to happen: No indenting would be added to the tags. Or, once I exited the list the indenting added for the list would have been removed from the tags.
Hello, unfortunately that’s how lists works with common mark: a blank like is required to “close” the list otherwise the last line is interpreted as part of the last list item.
