TOC / Stats not refreshing
Testing version: 1.0 (2510), but also before
What were you doing: Few files open (as tabs). TOC / Stats window is floating
What feature did you use: TOC floating
What happened: When you change files, the content of TOC or Stats doesn’t change. No focus?
What did you expect to happen: Update it, based on what file I work on (the focus is on)
Hi there,
May I just ask, what device was this occurring on for you? and the system version you are using on the device? :slight_smile:
Latest Mojave. Intel Macbook Pro. 2019 or something :slight_smile:
Thank you for the additional information.
This may be a bug :beetle:, we’ll investigate further!
Hi there,
A follow-up to the above, I consulted with a member of the development team for more information on this.
They mentioned that the panel is related to a specific document. If you change tab, you will need to re-open it if you had it detached :slight_smile:
Sounds like pain, right? :slight_smile:
