Wikilinks not recognised if note doesn't exist first
Testing version: Version 2.0.1 (11708)
What were you doing: I was note X writing wikilink e.g. [[Bear notes]]. Then I went to note Y and started wikilink to do the same [[Be…
What feature did you use: wikilinks
What happened: I don’t get a suggestion for the wikilink “Bear notes” (because the note doesn’t exist).
What did you expect to happen: That if I’ve created a wikilink that it’s recognised system-wide, so I can write it in other notes too and interlink my notes this way.
However, this doesn’t happen as the actual note needs to exist first. Potentially creating a lot of empty notes.
The suggestions only include notes that exist, so that’s expected behaviour I would say. If you click on your first wiki link it creates the note though and then your other suggestions would work
On macOS version 2.05 (your version is old) non existing notes are listed in the autocomplete panel as long as a link to this note exist
How are you on that version?
This is what my TestFlight shows,
Screenshot 2023-07-30 at 18.39.04
Via AppStore and not TestFlight, for the official non-beta Bear :bear:
Thanks, I’ve apparently totally missed that Bear was officially out of beta and in App Store.
